Hey TB
txgrn
07-13-2005 20:21:38
Got a question for you sir. I have a newly acquired one and redid my batteries so she really rolls over and starts up real fast; much faster than with the 6v OEM type batteries.
What I found was I hear (heard) rumbling noises in the engine (I think... was in the cab) for about a second or two after the engine starts (if it has been sitting overnight or longer) which disappeared when the oil pressure gauge pops up showing pressure (and it pops up from 0 to 2:30 position instantaneously, no gradual rise like oil pressure gauges usually do).
Tractor has 4000 hrs on it and I believe it to be actual hours. Has been very well cared for and runs like a top with no noises or funny business. Excellent reaction to throttle advances and exhaust is clean.
Do any of yours do that and if so, what do you think about it. Don't want to tell you too much so as to not bias your response.
Thanks,
Mark
TBSCOTT
07-14-2005 08:06:06
 Re: Hey TB in reply to txgrn, 07-13-2005 20:21:38
All 3 of mine are still hooked up as 2 six volts. They range in hours from appx 3-4000 each. None of them do as described but someday should I have to go with 2 12volts i'll have to remember this. Only one had a little rattle when I shut it off but it turned out to be the hydraulic pump coupler bushings. Simple fix, do the belts while there. Good luck a very nice tractor, those who like the 4020's would loooovvveee the 4230.
txgrn
07-15-2005 07:18:56
 Re: Hey TB in reply to TBSCOTT, 07-14-2005 08:06:06
Having had a 4020 it is easy to see the improvements. I think Mother Deere did us a favor in this upgrade of a classic.
Mark
charlesmm
07-14-2005 00:42:07
Probably it fires up so much faster now so that oil pressure has less time to build,try holding the stop lever out for a few seconds , this is recommended anyway when the tractor has been standing a while or when the filter is changed
personally I would ignore it if it builds pressure fast and well and runs without knocks.significant wear or damage will make itself all too clear!!
txgrn
07-14-2005 05:14:12
 Re: Hey TB in reply to charlesmm, 07-14-2005 00:42:07
Well, I decided to do just that. I really redid the batteries for winter starting where it gets a lot of cranking B4 she fires off.
So in the summer, I will have to make her wait.
Thanks for the idea. Sounds good; makes sense.
Mark
