Early model B hand crank clutch bolts stick out to
CHRIS - GEORGIA
07-13-2005 16:33:16
I have a 1941 model B, and just bought a dust cover for the clutch. I tried to put the dust cover on but I noticed that the clutch adjustment bolts stick out past the housing and will not let the dust cover go all the way up. Does anyone know what could cause this. The 2 clutch disks are in right but I havent torn the whole gear out yet. If you have any ideas I would be grateful.
WTW
07-14-2005 11:48:31
 Re: Early model B hand crank clutch bolts stick ou in reply to CHRIS - GEORGIA, 07-13-2005 16:33:16
Chris, I have seen and run into this same thing. Here is what I can tell you from what I have learned. The clutch pulleys from 1935 through 1946 model B will all interchange. There is two or three different pulleys used in this era and they all "look" alike. You never know which one you may have on any given tractor because allot of parts have been swapped around over the years. There is three different part number for the clutch operating bolts that you are having problems with. I know for sure there is two different lengths. The different numbers for the three different bolts are: B147R, B1361R and B1856R. Three of the right number will correct your problem. Good Luck, DW
Tx Jim
07-14-2005 04:11:27
 toggles and dogs? in reply to CHRIS - GEORGIA, 07-13-2005 16:33:16
Chris,I think your toggles and dogs are worn letting bolts stick out too far.Tx Jim
BushogPapa
07-14-2005 03:51:18
Are you sure the clutch discs are not worn out..?
Not sure, but crankshaft end-play may affect this too....
I have seen worn or damaged clutch pivots cause this, but the clutch would not operate very well if they are in bad shape.. I would pull the entire pulley out and look it over..there is a grease fitting that needs service on the back side of the pulley anyway... Seldom gets any attention..!! Be careful turning those clutch-bolt nuts..don't force them, or you will either break your pulley, or damage the finger-shaped pivot the clutch bolt rests in... Ron.
CHRIS - GEORGIA
07-14-2005 10:00:19
 Re: Early model B hand crank clutch bolts stick ou in reply to BushogPapa, 07-14-2005 03:51:18
I am planning on pulling the whole pulley out this weekend to see if I can find any reason why they stick out so far. I did notice that whoever owned this tractor before I did was not very easy with the splines on the end of the crankshaft. Im going to have to work on them some, the clutch face that slides up on the gear tightens up fine and the carter key fits well too with the nut going on the end of the crank shaft just enought to get the key in. Im hoping for the best when I tear it out, I hope there isnt a spacer or someting missing, but the clutch works just fine and makes its distinctive popping sound. I thought someone might have changed the original bolts. I guess ill find out this weekend
BushogPapa
07-14-2005 10:34:46
 Re: Early model B hand crank clutch bolts stick ou in reply to CHRIS - GEORGIA, 07-14-2005 10:00:19
Have you ever pulled the clutch driver on one of these..? You will need a couple bolts..about 1/2" and a good plate to span the distance between them.. The plate will go over the end of the crankshaft and the bolts will go thru the plate.. This acts as a "Puller" for the clutch driver...
you may find that you have to smack the end of the crankshaft with a 3 or 4 lb hammer to get it to pop loose.. I like to put the bolt in the end of the crankshaft without the washer, and put the plate over that..it insures that you won't damage the crankshaft end.. I would at least replace the clutch lining that is behind the driver as it is the hardest one to get to... I hope all the mounts are intact for the pivots and toggles...! Be sure to grease the fitting back there, too..!! That is the only lubrication the operating sleeve and toggles get..! Clean and repack the clutch bearing and bushing too while you are at it... Let us know how it goes...!! Ron..
