70 power steering part interchangability?
Leeker
02-27-2004 14:52:25
Lookin to put power steering in my 1956 John Deere 70. I figure I need to do the complete swap, pedestal, pump and all. Who else has done this? What can I look for as far as cost goes? Can I only trade 70 for 70 or can I look into the 720/730 line as well?
Thanks!
Robert
02-28-2004 16:31:18
 Re: 70 power steering part interchangability? in reply to Leeker, 02-27-2004 14:52:25
If you need a complete unit I may have one for both tractors. Central Ill .If interested post here.
Clooney
02-27-2004 15:34:55
Leeker, I have done a few of those P/S installations on the numbered Deere's ..
~I really can't help you on the cost as I always buy a donor tractor with a working P/S system as that is the cheapest & easiest way to go.. I then re-seal the pump & install new steering vane seals while it's apart..
~On a couple conversions I even sold the [converted to manual steering tractor] for more than I paid for it so all I was out was the hauling & replacement seals & vanes.. On another I kept the donor tractor so I didn't gain anything there.
~Most of the 70 & 720/730 parts will interchange but you are better off with the late 720 & 730 pedestal as that has a better steering sleeve & internal gear operating parts..
~If you do buy the parts separately you really don't know if the parts are any good & a non working P/S system can be an expensive pain..
~If you use a donor tractor the 70 will be a much cheaper initial investment as 70 tractors are still quite a good value.. The problem is finding one with P/S that operates good at a decent price.
~About all you can do is start calling around & price the P/S parts out [make sure they will make the deal right if the system doesn't work,, a good possibility].. Then see what you can buy a working P/S tractor for & what you think you can re-sell it for without P/S.. In a lot of cases the lack of P/S doesn't hurt the value too much..
~It really isn't too difficult of a job it's just that a lot has to come apart & some of the parts are heavy.. About the biggest problem you will run into is getting the P/S pump off & on as a lot of times the radiator will have to be moved slightly to get the pump in & out..
[email protected]
