Early J.D. backhoe control valve problem
David Sherman
07-12-2005 21:46:08
I have a JD 2010 backhoe/loader setup. I can't find any model number on the backhoe, but it's probably from around 1965 of so. It uses a giant hydraulic motor (rather than a pair of cylinders) to pivot the backhoe boom. The control valve apparently leaks, since the boom swings all the way to the left within half a minute or so if I don't constantly finesse the valve. The backhoe valves are all in one block. I took the spool out of the leaking valve and couldn't see anything obviously wrong with it. Should I assume the spool and/or bore are worn, or is there something else that could be causing the leak? If the valve is worn out, is there anyway to rebuild it, and if so, who does that? Alternatively, is there any modern generic valve, like from Northern Hydraulic, that will fit in this JD block to replace the bad one? Thanks for any advice you can offer.
Jonathan in Ma
07-13-2005 15:21:42
 Re: Early J.D. backhoe control valve problem in reply to David Sherman, 07-12-2005 21:46:08
That swing device is not a motor but rather a large vane type cylinder...theres a reason they werent used for too long...they are no good....The swing problem is most likely an internal leak in the swing barrel assembly. If your lucky its only a matter of a seal kit...but theres probably more to it than that...."things" get loose in there and cause damage etc...I'd disasseble the swing cylinder and see what the problem is...then attack it as needed...might need the services of a machinist ...
David Sherman
07-13-2005 21:09:35
 Re: Early J.D. backhoe control valve problem in reply to Jonathan in Ma, 07-13-2005 15:21:42
Yikes! I'm already well into getting the swing valve out of the valve block. Valve rebuild kits are apparently no longer available, but the parts guy says there are "tons" of O-rings in there so I was hoping that one of them is responsible for the leak. If it's the cylinder, though, that's a whole 'nother problem.
I don't see how a leaky swing cylinder could swing the boom if the valve is closed in both directions, but I'm not real clear on how the whole thing's supposed to work anyway. For now, I just chain the boom in place when not using the hoe, but it's a real pain to try to dig anything while the boom keeps swinging to the side.
07-14-2005 17:19:34
 Re: Early J.D. backhoe control valve problem in reply to David Sherman, 07-13-2005 21:09:35
A quick check....disconnect the 2 lines going to the swing barrel and cap the lines...also have to plug the ports on the valve...if the hoe still swings by itself with the lines plugged , then its internally leaking in the barrel...if it stops moving on its own its in the valve..
msb
07-13-2005 07:34:06
Its either a model 50 or 51.I can't remember.I think it is a 51 for a wheel tractor and a 50 for a crawler tractor. There are o rings inside the valve ,but it must be torn down to get to them.I have a 3010TLB and I couldn't find a suitable replacement valve assembly at Northern Hydraulics
Mike M
07-13-2005 07:39:59
 Re: Early J.D. backhoe control valve problem in reply to msb, 07-13-2005 07:34:06
I was thinking that the difference between a 50 and a 51 was one was made so you could offset it on the back ?
TBSCOTT
07-13-2005 08:39:30
 Re: Early J.D. backhoe control valve problem in reply to Mike M, 07-13-2005 07:39:59
Yes, either will fit. the 50 is a center mount and the 51 can side shift to dig next to basements.
msb
07-13-2005 07:34:01
