4010D back to 24 volts
Jack-Iowa
07-12-2005 12:39:06
I have a 4010 diesel that I need batteres for and wanted to put it back to 24 volts instead of 12 volts.
Any ideas how to do this and or places I can find the info to put it right?
Also the 24 volt will be positive ground correct?
thanks
Mike M
07-13-2005 07:49:23
 Re: 4010D back to 24 volts in reply to Jack-Iowa, 07-12-2005 12:39:06
Saw a sign in the local motor shop that says you all are wrong on how they work ! Went something like---- Motors run on smoke,once the smoke gets out they are bad. LOL So keep the smoke in and they will work fine.
R. John Johnson
07-13-2005 07:08:05
I found this link in the archives. Hope this helps.
John
www.geocities.com/gwece/deere/
Jack-iowa
07-13-2005 09:29:27
 Re: 4010D back to 24 volts in reply to R. John Johnson, 07-13-2005 07:08:05
R.John Thank you thank you!Glad I am not the only one that found the manuals confusing!
Jack
Jack-Iowa
07-13-2005 05:36:49
Well any help on the wiring??
And for those that are using alternators how did you line up the pulleys?
Chip
07-13-2005 11:25:32
 Re: 4010D back to 24 volts in reply to Jack-Iowa, 07-13-2005 05:36:49
Put the generator pulley on the alternator,generator pulley takes wider belt. Drill holes in lower generator bracket closer to top edge so a long bolt will go thru bracket, alternator, pipe spacer, bracket rear. Use same belt. Remove old regulator. batA and BatB wires are hooked together and hook to alternator output post. One wire will go from key switch to old regulator this now hooks to alternator regulator plug-in to put voltage to regulator to make it charge. I believe a WHITE wire is connected to the same key wire at the alternator plug-in this wire goes to dash lite. If you really want exact specs I'll go out and get wire colors. Can even send you a picture. The theory is to use both batA and B wires to bring voltage back to key switch (didn't figure one medium diameter wire would take the increased output 55amp)
Chip
07-12-2005 19:32:07
My 24 volt starter broke the bendix, the starter shop talked me into a 12v denso gear reduction starter $265.00 and a delco altenator 55amp with built in regulator $35.00 Best money I've ever spent!!! Now I see Irska makes a starter less expensive. The gear reduction starter sounds like an old Chrysler car and it'll crank it over in any weather. The old generator only put out about 20amps and after a while the lights would go dim and the batteries were in need of a battery charger overnite, what a pain!
CPeter
07-12-2005 15:33:42
As was alluded to, this is an isolated ground system for the starter and generator and the lights only use the ground to carry the current from one to another. A clever, if not odd system, but it did reduce the number of components that might fail. Buickanddeere has good insight into this. Really not all that complicated one you get the gist of it. He explained it very well at the Expo.
CPeter
buickanddeere
07-12-2005 14:45:27
I have to eat some crow about 24V systems after talking to a retired Deere engineer. Seems Delco was playing $$$ games and sold Deere 24V starters with series windings inside. A 12V starter of similar power was the same except wired in parallel internally. All in all the stock Deere 24V starter will perform a little better than a 12v version built inside the same frame. This is due to line loss through battery cables, brushes etc. I had wondered how our past and missed friend Mike Hanley made his 730 winter start with good success on 12V. It has to be stated he spared no details in the batteries, cables, connections or starter it's self. And he did use electric pre-heaters. The 24V system is neither + or - ground for the starter, regulator or generator. One half of the 12V loads must be + ground and the other 1/2 negative ground. There is Ken's generator shop listed over at johnnypopper. He will build a quality 12V or 24V generator or alternator system and starter if need be for a reasonable price. You could go 24V and install a monster 24V starter that will whip that 4010 over and start when 12V systems won't in cold weather.
txgrn
07-12-2005 18:02:29
 Re: 4010D back to 24 volts in reply to buickanddeere, 07-12-2005 14:45:27
My starter is OEM. Don't know about it being a monster....it's the same size as the 12v on my 4230. My batteries are 950 cca OTR truck batteries and sit in a box on the frame just outside the starter. The connections are 3/8 lugs to studs (no lead) and the wires are 00 and none over 15".
Like you said; when I hit the starter, she pays attention; rain or shine, winter or summer.
Mark
Van in AR
07-12-2005 14:36:16
Youll need the wiring diagrams. One battery is hooked up neg ground and the other is hooked up pos ground. Wierd but works. Only starter is 24 volts, serviced by two seperate 12 volt systems.
Van
txgrn
07-12-2005 17:58:02
 Re: 4010D back to 24 volts in reply to Van in AR, 07-12-2005 14:36:16
The elect system is 24 volts which includes the starter, gen, and regl. The lights are setup with one side on one batt (A ckt) and the other on the other batt (B ckt). The idea is to keep an even load on the batteries cause the 24v gen puts out 24 plus volts and doesn't know, nor care, which battery gets what.
To get them to charge evenly, they need to be the same type and preferably age, and having had an even discharge, they will recharge evenly. The dash is set up on the pos grounded 12v batt; but the discharge is miniscule so it makes little difference.
The ignition switch has to have provisions for the A and B ckts.
Wiring diagram is essential.
Mark
Van in AR
07-12-2005 20:39:49
 Re: 4010D back to 24 volts in reply to txgrn, 07-12-2005 17:58:02
I stand corrected, forgot about the gen and reg.
Van
txgrn
07-13-2005 07:08:17
 10-4 in reply to Van in AR, 07-12-2005 20:39:49
Jack-Iowa
07-12-2005 15:06:11
Thanks for some info.I believe I have all the parts ,just do not know how to wire. Were can 1 find the wiring diagram? I have service,parts and operators manual but none of it is real clear.
Tom/Idaho
07-16-2005 05:37:29
 Re: 4010D back to 24 volts in reply to Jack-Iowa, 07-12-2005 15:06:11
Did you get a wireing diaghram? If not I have a really good one for a 4020D that should be the same. I could scan it in and send it to you if needed.
Tom/Idaho
