How deep is too deep
Jaker2
07-12-2005 10:41:11
I have a jd 70 diesel that I am debating on whether to bore it out or just re-ring it. One cylinder looks like it could be honed good and re-ringed and all would be good. The other cylinder has a few pits where it sat full of water for a while. They are probably 1/64th to 3/64ths of an inch deep maybe less. You can see and feel them. They diesel engine ran before I tore it down, but it had a leaking head gasket. When I got the head off I was looking at the cylinders and I am at a standstill.
My question is should I re-ring and go on or spend the money and have it bored? I am not going to use the tractor hard. The hardest it will be worked is driving in a parade or pulling a wagon for a hayride. Also where is a cheap place to buy rings? I believe jd has them for about 70 bucks a hole. Has anyone ever tried to use electronic ignition on a pony motor? Thanks Jake
Jaker2
07-12-2005 15:45:33
 Re: How deep is too deep in reply to Jaker2, 07-12-2005 10:41:11
First, thanks for all of the input. Next, to all of the questions, When I had the tractor running there was no sign of wet stacking, only moisture in the exhaust and if you let it set overnight the water somehow got in the water. That is the main reason I tore into was the water in the engine oil. After getting the head loose it was quite obvious that the head gasket was shot. Parts of the head gaskets by the copper rings were completely gone from the gasket. The engine ran good for the condition that it was in. It almost looks like someone was in this tractor at one time and give up after they had put some money into it. My guess is the head gasket is what turned them off. What kind of money should I expect to have to pay to have the engine bored and all of the parts to put it back together? 1k 2k or more. Btw, has anyone ever used a electronic ignition on a pony?
Thanks again for the help
Blksmok
07-13-2005 07:01:50
 Re: How deep is too deep in reply to Jaker2, 07-12-2005 15:45:33
Jake....you're at an all too familiar decision crossroad. Do you put 2000 dollars (first class engine overhaul) into a tractor that is worth about 2500 dollars? If the tractor has sentimental value, or if you intend to use the tractor to make a living (full time farming)...then do it right. But, if this will be a parade tractor and only see less than 20 hours of use per year then it's a different decision. The fun is that it's your decision either way.
720Deere
07-12-2005 17:21:01
The only way to install an electronic ignition on a pony motor would make a hideous mess. I have seen old farmer rigs where they used automotive coils. I don't know if it worked any better, but it sure looked bad.
There is nothing wrong with the original pony ignition if everything is up to snuff and set properly. The most common problem with them is lack of voltage with the newer style coils. Try running a jumper wire from the starter terminal to the pony distributor once and see if it runs better. Don't supply it full 6 volts for an extended time. If this works then you need to work on your ignition ballast to achieve upwards of 5 volts.
I have worked on three pony motors that didn't run worth crap to start with and they all run fine now. The coils are usually burnt up from someone giving it a 12 volt hotshot or worse yet using a 12 volt battery. If those coils smell funny, that's your problem. If set up right, they start easy and run like a top.
mike brown
07-12-2005 17:19:41
I have not bought those parts in afew years but I think the 2k figure would go a long way on a cylinders forward freshening up. As to your question about electronic ignition for the pony you have to take into account that the system as is is a wasted spark ignition. Both plugs on one side fire at the same instant but only one has a compressed fuel charge to ignite. The other plug is on an exhaust stroke and thus wasted. It could be tough to make use of the original distributor to time you electronic ignition. I used to have a 720D with pony start and I used four 6v car coils for the pony and used the points in the distributor to run them two at a time. Two for both rear plugs and two for the front. I made a rack for them that was hidden under the hood. Looked the same on the outside but started much better. Inexpensive to boot
G/MAN
07-12-2005 13:39:44
I agree with the other two gentlemen. Everything needs to be right to have a truly nice-running and good-performing two-banger diesel. The spark-ignition tractors can get by with a less-than-optimal ring seal etc, but to avoid wet-stacking, excessive smoke, fuel getting in the engine oil and other problems, a diesel needs to have up-to-par ring seal, compression and the fuel injection system needs to be in good shape.
Blksmok
07-12-2005 12:28:09
Jake...you say it ran before you tore it down..was there any signs of "wet stacking" from oil (not coolant)? If the inside of the muffler and exhaust pipe have heavy residue of black, wet soot, I would bore the cylinders and check the ring grooves on the pistons. Nothing worse than a parade tractor the spews out small black droplets. You will have the black measles, the parade watchers and hay wagon riders. If the inside of the exhaust channels are dry, I would just hone and re-ring.
buickanddeere
07-12-2005 11:49:52
The pistons and the entire length of the bores will have to be measured to get an accurate answer. Piston pin and ring groove wear is a factor as well. Which cylinder head is on her? The original head tended to crack. New pistons work better with the 5 hole 10 thou dia 140 degree injector tips. The old pistons and injectors are a matched set of 160 degree. Opinions vary on mixing and matching pistons and spray tips. Even for parade use the injectors need cleaning and re-setting to 2600psi. Flywheel splines, cam idler gear and cam endplay is critical.The injection rollers has to run the the middle of their cam ramps. Cam/follower wear needs checking too. If the injection pump lines in the windows are not timed true. The injection pump plunger bores and pistons will be ruined. Finding true top dead center while the heads are off is vital. The fuel transfer pump seals should be replaced when she's opened up. New seals in the cranking engine water pump are a good idea while they are handy.
mike brown
07-12-2005 13:41:59
 Re: How deep is too deep in reply to buickanddeere, 07-12-2005 11:49:52
"How deep is too deep" in your checking account? Welcome to the wonderful (expensive)world of opening up your two cylinder diesel! Our mantra is "as long as you've got it apart you should...." and "it's cheaper to fix it now than to have to go back in later". All of which is true and you'll end up with a great running tractor. I know because I've got 11 or 12 K into a 730D that runs great and is worth maybe 8K. But I'm proud of my tractor.
Mike M
07-13-2005 04:42:55
 Re: How deep is too deep in reply to mike brown, 07-12-2005 13:41:59
Maybe it's a mike thing ? I got one of those also a 720 D.and maybe 10 other gas jobs. How far is too far ? I like to go as far as you can---bare and empty main case.Then turn around and put it back together.Very,very time consuming,some of them get real expensive,some aren't too bad. But I will tell you there is no comparison in the quailty and drivabilty once your done.
