Model D Differential
Bill Irsik
02-27-2004 12:35:37
I,m restoring a 1937 John Deere Model D. The parts book I have calls for a .065 thrust washer(D1081R) between the side gear and inner bearing thrust washer(D143R). There were no thrust washers in this area when I tore it down, however,the washer called for would reduce the amount of clearence I have perfectly to the clearence called for. Does any one know if this was a production change after these tractors were built? Also, these thrust washers are no longer available, has anyone had these made and would possibly know the metal hardness. Better yet, does anyone have any they would like to sell. I've gotten the measurements from Greg Stephens. If I can find the originals I would prefer not to have them made. These are not the shims used in the Quills(24H86R).
Clooney
02-27-2004 13:07:34
 Re: Model D Differential in reply to Bill Irsik, 02-27-2004 12:35:37
Bill, I don't know if that D1081R was put in the production tractors or was a service part for taking up the slack on a worn diff.. I did 37 D a couple of years ago & that washer wasn't in mine either. I don't remember what the thickness was on the ones I used but I just used a couple of automatic transmission thrust washers with the correct ID.. If I remember correctly it took 2 or 3 thinner washers to get the slop out.
~If you can't find what you are looking for try a local trans shop..
[email protected]
