Model 60 Clutch
Barry Rhoads
07-12-2005 08:00:35
Completely disassembled and cleaned clutch, replaced all the replacable components in clutch including new springs. Assembly does not sem to sit completley centered in the pulley. I attribute this to the long clutch bolts and springs??? This 60 has the one piece bearing assembly. In short the clutch has a growling sound and vibrates as the RPM increases. Seems to snap over fine and does not slip. Any thoughts would be greatly appreciated.
jas
07-13-2005 13:46:11
 Re: Model 60 Clutch in reply to Barry Rhoads, 07-12-2005 08:00:35
Did you put the clutch drive on the correct spline of the crankshaft? Some can only go on one way but I have known some to go on reguardless of the marks lining up. Just my $.02
Barry Rhoads
07-13-2005 18:55:16
 Re: Model 60 Clutch in reply to jas, 07-13-2005 13:46:11
Jas,
I appreciate the reply. I made sure the weighted gear went on with the "V" marks lined up. Mine does have a crack in it. Do you know if there would be balance problems in using another gear off of a 60 as long as the "V" marks lined up??
Thanks,
Barry
