'43 JD B oil level check?
neal
07-12-2005 05:30:11
Hi
I just got a '43 JD B and haven't got a manual yet. Can some tell me where the engine oil level plug is? It is a hand start if that matters.
Thank you for your help.
Neal
07-12-2005 13:16:47
 Re: '43 JD B oil level check? in reply to neal, 07-12-2005 05:30:11
Thank you all for your help. I will order a manual hopefully this month. Neal
MITCHP
07-12-2005 07:21:33
Neal and Pat too, didn't know if you guys knew this but when ordering a parts manual from deere give them the part number but add "CC" after it. It will be the same parts manual but the john deere collectors center made alot of manuals years ago but never sold all of them, you'll get one of these, same book but the pages are yellowish instead of white and the front cover is different. The good thing?? price is half of a regular manual, the one for my A was $26 instead of $42
Pat Browning
07-12-2005 06:30:25
Hi Neal -- Just behind & inside the flywheel, several inches forward of, and some 5-6 inches below the crankshaft (flywheel center), see a 3/4-inch two-part fitting. This is the oil-level test cock. The engine's oil level is full if, when you back the test screw out a couple turns, oil runs out. (I have heard reports that folks are finding a standard pipe plug there -- I hope yours is a standard JD test cock). Also, test the viscosity of that oil with our fingers -- testing it for having been thinned by seepage of fuel, through the engine, into the crankcase.
If you would like a picture, e-mail me -- [email protected]
And be sure you do obtain manuals soon for your tractor. There are any number of sources -- and JD Pubs is one of them (800) 522-7448.
mitchp
07-12-2005 06:22:35
You can tell when it's full by opening the little petcock on the side of the main case. When the oil drips out, it is FULL. The petcock is located just below and in front of the crankshaft. It can be on either side of the tractor. If your tractor is a "hand-start", it'll generally be on the flywheel side. It'll probably take a 3/4" wrench
