730 smokes when started
Pinkerton
07-11-2005 17:23:26
My 730 gas has been overhauled and smokes badly when started. It does not do it when I have the oil bath off of it. It is filled with 30 weight oil to the fill line. I did have the oil bath screen cooked out for a couple hours but didnt help. thanks
Mike M
07-12-2005 05:12:45
 Re: 730 smokes when started in reply to Pinkerton, 07-11-2005 17:23:26
What is your definition of "overhauled" ? If everything was brought back up to spec. like valve guides and cyl. wall clearances then it may just need broken in . Go out and work it.
Pinkerton
07-11-2005 17:51:43
It smokes blue badly when started. It does not do it with the oil bath off. The oil bath screen looks clean after it was cooked out. Still does it though. thanks Paul
buickanddeere
07-12-2005 05:42:46
 Re: 730 smokes when started in reply to Pinkerton, 07-11-2005 17:51:43
Any restrictions in the rest of the intake plumbing?
mike brown
07-12-2005 04:16:14
Does it clean up after it starts?
mike brown
07-11-2005 17:47:35
Blue smoke or black.
Blue=sucking in oil from some where, maybe the oil bath air cleaner.
Black= Reduced air flow through the air cleaner choking it.
