855 PTO Problems
Flyingbeagle71
07-11-2005 08:07:25
Hi all, I have a JD 855 that is blowing the PTO fuse. Mostly it blows when the PTO is under load and the tractor is moving and hitting bumps. I thought it might be a shorting problem in the wires from the switch but have not found any problems yet. Anyone else run into this problem?
F-I-T
07-11-2005 09:39:52
 Re: 855 PTO Problems in reply to Flyingbeagle71, 07-11-2005 08:07:25
I have an 855, too, and the pto circuit is kind of unique. There is a mechanical linkage to the rear end which actually engages/disengages the pto clutch. The only thing electrical about it is that the lever on the dash is attached to this mechanical link by an electromagnetic pad that holds the lever to the mechanical system. If anything goes wrong, or the fuse blows, or the operator stands up, the circuit is interupted and the electromagnetic bond is broken and the spring loaded mechanical linkakge moves to disengaged.
That said, I would investigate for a short in electromagnetic circuit. if you had said it just falls out of engage, I would suspect the seat switch.
If you have a book there is a super trouble shooting section regarding the pto. It shows that there are two fuses for the PTO. Which one is blowing is significant. One runs from the ACC side of the ignition switch and fires the DCC Timer and runs through the seat switch and the onto the lever magnet. I suspect this is the one that is blowing. The other one runs from the IGN side of the ignition switch, through the PTO panel lamp. When your fuse blows, if the PTO panel lamp still glows, then you are burning out the fuse on the magnet side.
Start by replacing the fuse check for good voltage and no bare wires starting at the ignition switch, and then to the seat switch. Follow this wire to the PTO selector switch (Rear/Mid/Both). Check from there to the PTO lever magnet under the left side of the dash. I think you have a short in this line which is blowing the fuse.
It runs YEL/RED from the ign switch to the fuse, then YEL into the seat switch. From the seat switch it turns BLU to the PTO selector switch, then BLU to the PTO magnet.
THat should get you started.
Frank
flyingbeagle71
11-01-2005 08:31:48
 Re: 855 PTO Problems in reply to F-I-T, 07-11-2005 09:39:52
F-I-T, you were right, it was the seat switch. Easy fix once I finally took the time to look at it. Thanks again for the advice.
flyingbeagle71
07-11-2005 10:16:27
Thanks for the information Frank. From what you posted I am suspecting the PTO switch, the last owner had rigged a little friction bar along side the PTO lever, probably because the electromagnetic pad isn"t working. The light on the indicator is still glowing once the fuse blows so it"s on the magnet side...
Which book do are you referring to for the trouble shooting section. I have the technical manual from John Deere, but it doesn"t even mention the fuse and goes right into trouble shooting the internal mechanical guts of the pto system.
Thanks again for the great information!!!
F-I-T
07-11-2005 10:21:24
 Re: 855 PTO Problems in reply to flyingbeagle71, 07-11-2005 10:16:27
I'm looking at the technical manual from Deere, TM1360, page 240-15-20 is the schematic.
