HELP!! rod problems
Pump Handle Bob
07-11-2005 00:48:54
the neighbor girl asked if she could help me by driving the tractor and baler while I stack the racks. I agreed, but after we got to the feild, she stripped to her bikini....top and bottom. Said she needed to Tan. Well you see, she out grew this bikini several years ago and the feild is a littke rough in places. I didn"t mind, but my wife got an eyeful and is furious. Now my question is, will useing a heavier weight motor oil in my 2520 reduce the knocking in the engine
Henry J
07-11-2005 10:55:22
 Re: HELP!! rod problems in reply to Pump Handle Bob, 07-11-2005 00:48:54
pump handle
I think you ought to have another try at it without the bikini. That may narrow down which rod was knocking. :-)
Mike M
07-11-2005 10:35:24
We sure need you to post some pictures of this problem !
Glen in TX
07-11-2005 10:24:34
You could also have a timing or fuel problem or balancer shaft going out on that engine making excessive noise like that. Is is using oil or low oil pressure? Take the sender off side of engine and plumb in a mechanical guage while you run it some to check it. Could that noise have been your eyeballs rolling around?? lol.
Maark
07-11-2005 08:23:39
That noise you think is a rod knocking could be the nylon bushings on the hydraulic pump coulper or the coupler loose on the pump splines at the front of the engine.
