720 Pony motor will not start
Gary W. Emmick
07-10-2005 20:28:20
I need some help, I can not get this pony motor to start? I put new rings in and coils, resitor.
Dan in Ohio
07-11-2005 06:00:24
 Re: 720 Pony motor will not start in reply to Gary W. Emmick, 07-10-2005 20:28:20
Gary, You know the things to check, compression, fuel , and spark. The easiest to check and my best guess is you are not getting fuel. If your tractor has the oil pressure fuel shut off valve, by pass it and run fuel directly to the carb. Check the timing as that is relatively easy. For other ideas go to the archives and search "pony" . Last summer I spent alot of time dealing with this same problem. I ended up taking off the oil pressure fuel shut off valve and the problem was solved. I even put new diaphrams in the valve and it still would not work. You'll get her started, alot of guys here can help.
dirtjockey
07-10-2005 20:33:09
I take it after putting in new rings that the valves were ground and a compression test done? Does it seem like a lack of fuel or spark? was the timing check to make sure it correct?
