MArk: ~~1. How hard are the flywheel ring gears to replace? First off, I would advise that you have an I&T manual or even better, the Deere service manual for the '730 Diesel' before you go too far. Your repairs are not difficult but they can get expensive in a hurry if you try to do things without reference materials. There is no trick to removing/replacing the ring gear on the flywheel but on a diesel, if you are in there that far, it's a great time to check and set the crankshaft endplay. Start by removing the "tin" nut with a large pliers or a pipe wrench. Then remove the two clamping bolts. At this time note the position of the flywheel relative to the crankshaft (mark it if it is not marked). The flywheel needs to go back on the correct slot and spline. Now slide the flywheel off. A hoist is VERY helpful but not necessary. Note that the oil slinger/spacer behind the flywheel has a notch to coincide with the small driver behind the flywheel. You'll want to reassemble with that slot on that point of the crank so the flywheel slides on all the way and engages that driver into the slot. Anyway, the ring gear is a press on item. I replaced one on a 70 Diesel a few monhts back, and I removed it using a 3 lb hammer and blunt chisel. To install, I laid the flywheel face down and laid the ring gear (with the correct side beveled up so it would engage the starter correctly). Then I began to warm the ring gear in a large circular pattern using a rosebud torch tip. After a few minutes the ring gear expanded enough to begin to fall on. I stopped the heat and drove the ring gear to its seat using the blunt chisel and the hammer. It went on very easily. Let it cool for a LONG time as the mass of the flywheel will hold a lot of heat for a long time. To reinstall, it really helps to have a dial indicator to set the crankshaft endplay to .005-.010". The book will detail that and you should have read the book several times so you understand what is going to be needed. THere is auite a bit to do involving the thrust washers. Also now is a good time to replace the clamp bolts with new grade 8 hardware. Torque them correctly. Over torquing with an uncalibrated cheater bar just weakens the bolt by stretching it, rendering it useless for its intended purpose. ~~2. Are they available? Expensive? Last one I priced new was $300 from Deere, but found a good used one on a cracker flywheel for around $75. ~~3. Should I plan on replacing the starter pinion on the pony? Probably so. ~~4. How bad is THAT to replace? New the price is around $300, but good used ones are around again for about $75. To replace it you should (you don't need to but it's easiest) remove the pony with a hoist and then you can pull the pony transmission apart and probably at that time replace the three bearings in it, a couple of oil seals, and check the over running clutch for wear. If it has any, there are a few things you can do short of feeding them money. ~~5. Finally, this seems to mean the motor is always stopping in about the same place. Is this normal or does it argue for some other problem? Nope, that's the nature of the beast. They stop at one spot. Some folks shut them down by pulling on the decompression lever so that the diesel engine flywheel will coast to a neutral position everytime. I mean, it probably took 45 years to wear this much..... Frank
