polarity?
buss
07-10-2005 08:38:39
on an A what is the correct post for ground. went out to my barbers place and he has all kinds of troubles electric wise on it . Will go back later this week and help him. Also he said there was a solonoid on starter. Starter won,t even buss and what kind of driver does flywheel cover use. Haven,t workedon deeres since was a kid and then not much as we didn,t own one Thanks in advance
F-I-T
07-10-2005 09:30:51
 Re: polarity? in reply to buss, 07-10-2005 08:38:39
Buss:
From the factory, all JD two cylinders were positive ground. Often times folks "convert" them them to negative ground for use with a particular alternator conversion.
Only a few "A"s had a solenoid on the starter from the factory, and those were, I believe, some of the AR/AO chassis. the general purpose "A"s used a mechanical switch that you pressed with your foot to engage the Bendix and supply power.
On the flywheel, I'm not sure whether you are speaking of the hand crank driver or the Bendix driver of the starter. On the hand crank driver, which resembles a crank end fork that is about 6" long and meant to fit into the steering wheel, engages the pin in the end of the crankshaft.
Frank
buss
07-10-2005 09:51:17
 Re: polarity? in reply to F-I-T, 07-10-2005 09:30:51
thanks The screw heads I am talking about are the ones holding the tin ware over flywheel, sort of a rectangle slot about 1/4 in wide
F-I-T
07-10-2005 10:12:02
 Re: polarity? in reply to buss, 07-10-2005 09:51:17
Those are called CLutch head bolts and you can remove them using a flat blade screw drive that fits the widest portion and then turn it out. You can get a "proper" driver from SK and other tool companies if you really feel the need.
buss
07-10-2005 17:32:20
 Re: polarity? in reply to F-I-T, 07-10-2005 10:12:02
thanks you jogged my memory after reading it it came to light thanks again
