420 j.d. front end
THEkyroastnear
07-09-2005 19:38:04
few days ago nearly lost pivot pin from front end. friend drove up& noticed.after looking did not even have right bolt to hold pin in. had this tract. about 4 yrs. never had front end problems before.any how got correct bolt from dealer a set-screw jam-nut deal similar to what holds starter. set -screw is raised but blunt on end i wonder should the pin have a recess or something to hold set screw in place? i have looked but not finding anything like that. starting to think pin has been fabricated on a lathe any help or info. sorry for long post
THEkyroastnear
07-12-2005 19:48:17
 Re: 420 j.d. front end in reply to THEkyroastnear, 07-09-2005 19:38:04
got everything straightened out this past wknd. pin is correct recess is there just had to take it all the way out to find it was a little scared to do it thought everything would get out of alignment where i couldnt get it back. all is well till something else comes up thanks to all
Henry J
07-09-2005 20:23:48
roastner
What kind of 420 you have?
THEkyroastnear
07-09-2005 21:16:28
 Re: 420 j.d. front end in reply to Henry J, 07-09-2005 20:23:48
its a w.f. i believe the dealership called it special utility not to mean agarden tract. but farm trac.
buickanddeere
07-10-2005 06:08:17
 Re: 420 j.d. front end in reply to THEkyroastnear, 07-09-2005 21:16:28
There is a standard, utility, row crop utility, V, High crop and an industrial front that will bolt onto your 1956 420. All are wide fronts. And goodness only knows what may have been swapped around during the past 49 years. A picture is worth a thousand words. If you have the parts manual in hand, then the process of narrowing down and finding the correct parts is fast, certain and easy. 1-800-522-7448 for the info.
Wayne in Tn.
07-10-2005 07:23:50
 Re: 420 j.d. front end in reply to buickanddeere, 07-10-2005 06:08:17
If you have the correct pivot pin, then it should have a recessed or countersunk hole for the lock bolt to fit into. You may have to rotate and slide the pin back and forth to find it. Its hard to find by just looking through the threaded hole in the housing.
