How clean should hydraulic filter be when changing
DuaneD
07-09-2005 18:31:38
I just changed the hydraulic fluid and filter in my 2020 diesel. In the bottom of the screen there was a little grey "dust". Similarly, in the bottom of the housing for the filter was a little grey dust.
Is this normal? Or should it be perfectly clean? Should I be worried about the brakes? This is a '66 tractor (I've owned it since 2000) and it is probably safe to assume the brakes have never been touched.
Thanks for any advice.
Glen in TX
07-09-2005 22:21:06
 Re: How clean should hydraulic filter be when chan in reply to DuaneD, 07-09-2005 18:31:38
That is normal to see. When you see chunks or fibers in filter and can its time to be concerned.
msb
07-09-2005 19:19:46
Its not unusual.Rinse it out with some solvent and put a new filter in it.I use mineral spirits.
