I need some help please-hydraulics
Willy P
07-08-2005 19:14:29
On my 2640 the hydraulics quit and I replaced the pto drum and checked all the lines and the transmission pump is putting out oil good and now run it a little while for the oil to get hot and then the hydraulics quit working-steering and all but pto kill the engine and start back up in a couple of minutes and everything works and the oil resevoir above the pump is empty and let it run for a couple of minutes and it will fill it back up and then 20 minutes or so the hydraulics quit again and start all over again,sounds like a valve might be sticking and when you kill it ,it opens back up but which valve? Any help would be greatly appreciated Thank You
Mike in Illinois City
09-28-2005 11:35:21
 Re: I need some help please-hydraulics in reply to Willy P, 07-08-2005 19:14:29
I have a "79 2640 that did the same thing. What happened in my situation was the hydraulic filter was plugging up with very fine metal particles due to the brake lining being gone on one of the brake disks. I"d shut it down for 15 minutes which would allow the particles to fall away from the filter and the hydraulics would work once again - but only for 10 minutes or so. The fix was two new disk rotors, 2 new filters, and new JD hydraulic oil. To replace the rotors the rear axles have to be removed.
