Dummy Question about a Dummy Plug
Fred from Mo
07-08-2005 02:55:30
In the power trol for my 60 are 2 plugs. Both have open fronts that allow the 3 point to work. I have ordered a AAR5724R selector valve for the top port of the power trol and have plumbed the side of the trol where the pipe plugs go with pioneer fittings for my 45 loader. In order to get the loader to work, can I leave one of these original open front plugs in the bottom port of the power trol. Are these open front plugs considered to be "dummy plugs", or am I just the "dummy?" and is there another stlyle of plug I need-Thanks
Mike M
07-08-2005 05:20:02
 Re: Dummy Question about a Dummy Plug in reply to Fred from Mo, 07-08-2005 02:55:30
OR, If your loader has a mech. dump you can just leave everything as is. Just hook the hoses into the RH side of the hyd. box with your quick couplers. What will happen is your 3pt. will raise first because it has least resistance,then you can run the loader up and down normally and the 3pt will stay up.I ran my model 50 this way for years.
F-I-T
07-08-2005 03:47:06
Fred:
You will replace one of the open end plugs with the AA5724R selector valve and let the other open end plug in its original hole.
Frank
