3020 Gas Starting Idea?
Playfarmer
07-07-2005 19:21:34
I was wondering (thinking to much) if a guy took a short piece of hydraulic hose and put it between the two remotes and wired the control lever open if that would let the oil flow and thus relieve the pressure so that the tractor would start any easier. What do you guys think? Thanks for your input.
buickanddeere
07-10-2005 06:27:02
 Re: 3020 Gas Starting Idea? in reply to Playfarmer, 07-07-2005 19:21:34
$3.00 and five minutes will let you completely shut off the front high pressure pump. What is the voltage across the coil while the points are closed and the engine cranking? What is the voltage between the large brass post and the cast body of the starter while cranking? What is the voltage measured from post to post, not clamp to clamp while cranking? Dropping from 11.0V to 7.8V cuts starter power in half.
kj(SE IL)
07-08-2005 05:18:01
try turning the steering wheel back and forth while cranking, always helps on granpas gasser 4020.
matthies
07-07-2005 20:24:45
Oil flowing is more than likely your starting problem, otherwise you are just adding to your problem instead of helping it. One thing you can do is unhook the pump coupler on the engine pulley and see if it starts better, if it does start better, then start capping off hyd. functions to see where the problem is. If it doesn't, then start with some ign. components like coil etc. I had a coil kick my butt for a while on a lp burner.
K.B.-826
07-07-2005 20:11:18
I suspect you have other issues. A 3020 gas should pop right off no matter what. Might want to look into your starting, charging, and ignition systems first. On the bigger diesels, turning the steering wheel while starting helps. You could also just get the destroking screw from your dealer.
SMA in NE
07-11-2005 12:35:54
 Re: 3020 Gas Starting Idea? in reply to K.B.-826, 07-07-2005 20:11:18
I have a gas 4020. I did run a hose from the rear outlet and right back into the same outlet. I had the lever for the valve open and it did eliminate hydraulic pressure buildup as you are hoping for. John Deere supposedly makes an electric valve that can be installed on the hydraulic lines near the pump in front of the tractor. When you engage the starter the valve allows the oil to bypass eliminating hydraulic pressure build up. My 4020 starts alot harder when warm than cold also.
