'D' fly wheel question
travis tietjen
07-07-2005 18:48:51
we have an old styled d that has has a starter witch dosnt work and ssince we only use it a few times a year we were wondering if it is possible and would work to take a fly wheel off of a hand crank d and start it that way?? if anyone has ever done this or just know if it will or willnot work pleez let me know thanks travis
PeterE
07-08-2005 10:43:18
 Re: 'D' fly wheel question in reply to travis tietjen, 07-07-2005 18:48:51
I've hand cranked my electric start B. There is a stub shaft available from John Deere that fits the steering wheel (assuming you can get the steering wheel off). Then you put in in the flywheel (there is an access hole on the cover) and turn it over.
I ordered the stub shaft from my local dealer. I've been told it is the same part for all of the bigger letter series tractors, but I do not know that for certain.
Glen in TX
07-08-2005 09:43:57
Don't know where you are at? I have some hand start D flywheels too. Like Tyler said you can drive the ring gear off and start it that way too. Some electric start flywheels had the finger grips in back and some didn't. I have seen D rings gears knocked off and tied over against tractor with baling wire so they could start them by hand because they didn't want to remove the flywheel. They made a stub shaft with pin to fit in steering wheel to engage the slots on cast piece bolted to flywheel but a D is kinda hard to turn over that way.
Van in AR
07-08-2005 08:54:48
I have a D hand start flywheel I would part with.
Van
TylerARK
07-08-2005 05:57:53
Travis,
You can either put a handstart flywheel on it or just take the ring gear off your flywheel and use it. I have seen a few that were electric start that someone had just taken the ring gear off and nade a hand start out of it.
OR , If you arent real far away, I might swap you a handstart flywheel and the hand start top cover for your flywheel , starter and starter mount....
Thanks, Tyler
