Distibutor conversion question
clinard
07-07-2005 12:28:53
After a coil failure, I converted my Wico C to a external coil type, its uses the battery like a delco. Question: the delco points set on .021, should I open up the wico C to the same gap instead of .015?
Glen in TX
07-08-2005 09:37:01
 Re: Distibutor conversion question in reply to clinard, 07-07-2005 12:28:53
All you can do is set it where it might run the best. You don't have the advance on that mag that a real battery distributor would have and it may not run as well as you would expect all though it will run.
Pappy
07-07-2005 21:12:08
Yes---open the points to .020. That will give it the proper dwell. You will have to re-set the timing as this will advance the ignition timing.
txgrn
07-07-2005 14:00:02
Do it and see what happens. Haven't lost anything but 15 minutes.
Mark
