JD 2000 series backhoe/loader
Dave H (NY)
02-27-2004 04:29:54
I am looking for somewhere to buy parts for a 2000 series backhoe/loader. The machine is a late 60's early 70's model the book says John Deere 2000 series tractor. I am trying to find brakes for it and am not having any luck. The brakes look almost like a miniature clutch setup and they are located on each side of the primary drive. Any help is appreciated.
Jack
02-27-2004 10:43:30
 Re: JD 2000 series backhoe/loader in reply to Dave H (NY), 02-27-2004 04:29:54
When working on the brakes, new discs can decide to 'lock' when applied if the case is too worn (common occurance). I have fixed this problem with satisfactory results via 2 different methods over the years: 1) Have machine shop plane down the outer case slightly, keeping the expanding mechanism from rolling the balls past detent stop, or 2) Using slightly larger balls, such that detent stop cannot be reached.
No matter what you do, they probably won't work well anyway, but they will be better than 'dropping the bucket' (or kicking the bucket, for that matter!)
jdemaris
02-27-2004 05:53:27
If you're describing the 2010 machine, it was early to mid 60s vintage. My Deere service manuals refer to the 2010 as the "2000" series, and my 1010 as the "1000" series. I was a Deere mechanic and worked on some 2010s when they were new and many when they were old. I NEVER came across one that had brakes that were worth a damn. Best case scenario - they would stop the tractor on a hill with a lot of effort, but you better not have anything heavy hooked to your drawbar. We used to send out the steel plates to a machine shop and have grooves cut into them - which in theory - improved performance. As far as availability goes, last time I checked they were still available through Deere. I've also sent out old ones for relining. Seems they tend to get glazed more than worn out. My memory is probably off a little bit, but I think the late serial # 2000 series had some slight improvements in the braking.
Dave H (NY)
02-27-2004 06:21:37
 Re: Re: JD 2000 series backhoe/loader in reply to jdemaris, 02-27-2004 05:53:27
It is the 2010 model, this is my first time working on one of these machines I am used to farm tractors and cars. This 2010 belongs to a nieghbor who does not have the knowledge to repair it and said if I fix it I can have free use of it, so I am trying to find out where to go for parts. The problem is the brakes are absolutely useless it has to be stopped by dropping the front loader bucket.
jdemaris
02-27-2004 06:42:30
 Re: Re: Re: JD 2000 series backhoe/loader in reply to Dave H (NY), 02-27-2004 06:21:37
Yeah, I know what you mean. We sold new ones that didn't stop much better. The 2010 was available as a farm tractor, industrial tractor (backhoe,loader, forklift, etc.) and as a crawler. I think the farm tractor has the same brakes as the industrial wheel tractor. They all are pretty bad. I live in a mountainous area of New York, most work is up an down hills. 2010s are not very good for such work - much better off on flat land. I think the best you can hope for - with everything perfect - is a machine that will just barely stop on a hill with nothing hooked to it. Once the brakes get a little glazed, or get oil on them, you can hardly tell they exist. If you intend to work on it, best approach is fix any oil leaks if they exist - and - if the linings are still intact - just clean and rough them up. New ones from Deere will probably be a couple of hundred dollars and will not provide earth-shattering braking - unless you crash the tractor. I've got several other tractors that have similar braking systems but work, at least, a little better. My Case 580CK backhoe, my Case VAC, my IH B-275, and my Case DC tractors - all have the little splined brake disks - but they all work better than Deere 2010 wheel tractors.
Dave H (NY)
02-27-2004 10:27:02
 Re: Re: Re: Re: JD 2000 series backhoe/loader in reply to jdemaris, 02-27-2004 06:42:30
Thanks for the input I'm also located in upstate New York in Orange county just below Ulster. I will try and locate new brakes for the 2010 that's what the owner wants but I will definately be sure about the oil leaks.
jdemaris
02-27-2004 16:15:52
 Re: Re: Re: Re: Re: JD 2000 series backhoe/loader in reply to Dave H (NY), 02-27-2004 10:27:02
I used to work for a couple of dealers down there including Gordons John Deere near Chester and Goshen; don't know if still exists or not. Also worked for a dealer in the black-dirt area of Florida/Sugar Loaf (Dombrowski's), and also in Middletown (Bellows and May). Used to vacation over 40 years ago on Mirror Lake in Ulster Park - but I'll stop. Guess this doesn't have much to do with tractors.
