GP axle quill removal
Lynda
07-06-2005 18:22:11
We are take my gp down to the case so we can get it sand blasted we are having trouble getting off the left hand side quill. the right side came off fairly easy. What is the trick? We put the nuts back on the studs and put spacer plates and reversed the nuts to work like a press but. afriad it may hurt the quill. Thanks Lynda
Chooch
07-07-2005 09:14:25
 Re: GP axle quill removal in reply to Lynda, 07-06-2005 18:22:11
Lynda,
Have you removed the bull gear from the transmission case? As I recall, the left hand quill extends into the transmission case and provides a housing for the bearing on the left side of the bull gear. There are also two dowel pins connecting the quill to the main case. I usually take a small chisel and drive it between the main case and the quill at the location of each dowel. I have taken several apart this way and fortunately have not had any damaged.
By the way, you might reconsider sand blasting the main case. It will be next to impossible to remove all of the sand from some of the cracks and crevices located inside the main case. Instead, I would recommend either a good steam cleaning of the inside and wire wheel on the outside or my preferred method is to submerge it in a tank and use electrolysis to remove the grease, paint and rust. When it comes out of the tank, give it a good steam cleaning and it should be ready to prep for paint. Let me know if you would like the link to a website which explains how it works.
Chooch
