Hood Removal
yoyo
07-06-2005 18:08:38
I have taken every bolt loose on my Model A JD and the hood will not come off. Do you have to remove the steering wheel shaft? Or is there some other way that I can remove the hood?
F-I-T
07-06-2005 18:41:34
 Re: Hood Removal in reply to yoyo, 07-06-2005 18:08:38
YY:
What year is it? If it's a styled model, yes, you have to remove the steering shaft. It comes out by removing the front medallion, then the front bearing cap. After removing the steering wheel, it will "screw" out forward with the worm unscrewing from the sector gear. The aft bearing cage may come out as well if the goop keeps it stuck to the shaft. Don't lose it in the slop if it stays put.
Frank
Heat Houser
07-06-2005 18:38:09
I am assuming a styled A.
Since the steering shaft runs through a hole in the hood, yes, the shaft will have to be removed. Pull the steering wheel, pull the front pedestal cover, remove the two steering shaft end cap bolts, turn the shaft to use the worm gear to force the shaft out, then withdraw the shaft completely.
