60 Ring Gear and starter teeth worn-now what?
Fred from MO
07-06-2005 16:00:33
My starter has been grinding the last couple of times when starting my 60. After removing the flyweel cover and inspecting the ring gear I noticed that 2/3rds of the teeth are shot on the ring gear, and the gear on the starter has some teeth missing as well. I don"t know what caused this? Any suggestions?? Is the ring gear on the flywheel pressed on and is it replacable? I have not had the flyweel off nor the starter yet, any tricks or advice would be appreciated. I always get good suggestions from the folks on this forum.
F-I-T
07-06-2005 16:42:36
 Re: 60 Ring Gear and starter teeth worn-now what? in reply to Fred from MO, 07-06-2005 16:00:33
My starter started grinding when I turned 50. HA!
Anyway, the ring gear is a press on item. I replaced one on a 70 Diesel a few monhts back, and I removed it using a 3 lb hammer and blunt chisel. To install, I laid the flywheel face down and laid the ring gear (with the correct side beveled up so it would engage the starter correctly). Then I began to warm the ring gear in a large circular pattern using a rosebud torch tip. After a few minutes the ring gear expanded enough to begin to fall on. I stopped the heat and drove the ring gear to its seat using the blunt chisel and the hammer. It went on very easily. Let it cool for a LONG time as the mass of the flywheel will hold a lot of heat for a long time.
What caused this? The starter teeth begin to wear and they sit upside down in dirt. When engaging, they carry this dirt into the ring gear, then all the wear expands. Then the starter doesn't engage all the way so the tips of the teeth start to erode. Then the starter gets repaired and gets a new gear, so the process begins anew, but since the ring gear is a lousy job to replace so the new starter gear buys you some time. 50 years later, it's time to fix it right.
The starter comes out the bottom and other than the cable and the three bolts holding it in, the only tough part is figuring out which way to roll and twist it to get it to fall out and hit you right in the chest. If it doesn't hit you in the chest like a decent defensive end, you made the job too easy, so something else will have to go wrong to make things equal with the tractor gods.
I you are replacing a ring gear, ask around to see if anyone has a cracked flywheel with a good gear. That's how I got a good one for this 70D.
Frank
Fred from MO
07-07-2005 02:23:35
 Re: 60 Ring Gear and starter teeth worn-now what? in reply to F-I-T, 07-06-2005 16:42:36
Thanks Frank!! You guys have always give me good advice. Is there a trick to removing the flywheel? I assume you took the ring gear off with the 3lb and a chisle while the flywheel was on the ground to prevent any damage to the crankshaft bearings. Also is there a trick to removing the starter gear once the starter is out?
F-I-T
07-07-2005 05:24:26
 On the flywheel.... in reply to Fred from MO, 07-07-2005 02:23:35
third party image
Fred:
First off, I would advise that you have an I&T manual or even better, the Deere service manual for the '60' before you go too far. Your repairs are not difficult but they can get expensive in a hurry if you try to do things without reference materials.
There is no trick to removing the flywheel. You just need a strong back and a weak mind. Start by removing the "tin" nut with a large pliers or a pipe wrench. Then remove the two clamping bolts. At this time note the position of the flywheel relative to the crankshaft (mark it if it is not marked). The flywheel needs to go back on the correct slot and spline. Now slide the flywheel off. A hoist is helpful but not necessary. Note that the oil slinger/spacer behind the flywheel has a notch to coincide with the small driver behind the flywheel. You'll want to reassemble with that slot on that point of the crank so the flywheel slides on all the way and engages that driver into the slot.
You said "I assume you took the ring gear off with the 3lb and a chisle while the flywheel was on the ground to prevent any damage to the crankshaft bearings."
No, not really. I took the flywheel off because there is no way to get the ring gear off without the flywheel being off the tractor, plus, it's probably not kind to the bearings, but I think a little hammer work is nothing compared to the force of ignition. But since you'll have to have it off anyway.....
To reinstall, it really helps to have a dial indicator to set the crankshaft endplay to .005-.010". Also now is a good time to replace the clamp bolts with new grade 8 hardware. Torque them correctly. Over torquing with an uncalibrated cheater bar just weakens the bolt by stretching it, rendering it useless for its intended purpose.
Frank
Daron
11-26-2005 16:49:26
 Re: On the flywheel.... in reply to F-I-T, 07-07-2005 05:24:26
What is the proper tourqe on the clamp bolts?
Many thanks...
F-I-T
07-07-2005 05:18:36
 On the starter..... in reply to Fred from MO, 07-07-2005 02:23:35
third party image
On the starter, you just remove the nose piece by loosening the two long fasteners in the opposite end of the starter. The "Bendix" mechanism that has the teeth on it will slide off of the splines, and a new one can go on. You might want to have a starter shop do this as it's a great time to get new brusheds installed and have it cleaned up. Money spent on starters is almost always good in my opinion.
Fred from Mo
07-08-2005 02:43:11
 Re: On the starter..... in reply to F-I-T, 07-07-2005 05:18:36
Thanks Frank, I will give this a try. I do have an IT manual that has helped out on some of these things I have never attempted before. It did have the flywheel removal in the instructions, but I could not find anything on the starter or the starter gear. I often find that the folks on this forum have a wealth of experience that the manuals can't tell you-such as yourself for instance. It has helped me out a lot with this tractor
