JD #9W mower - need parts
Paul Ward
07-06-2005 14:52:20
Can I still get parts for a #9 mower from the dealer?
If not, can anyone tell me a good source?
It is in pretty good shape overall but I need to replace the wear plates that go under the pressure fingers and replace some pressure fingers too. (I guess that's what you call them). They hold the cutters down tight against the stationary cutting edges on the guards. Thanks,
Paul
Craig-MN
07-06-2005 22:36:47
 Re: JD #9W mower - need parts in reply to Paul Ward, 07-06-2005 14:52:20
Yes, those parts are still available from Deere and also many aftermarket sources. Those wear parts are common to most or all of the JD sickle mowers made during the past 60 years. Check your local fleet&farm store for generic parts. Those "presser fingers" are usually called hold down clips if I recall.
There is a special wear plate on the inner end of the cutter bar (riveted to it) and they are spendy from Deere. I have some extra genuine Deere pieces I can sell you for less.
