In Need Of Manifold Bolts
StuckRusty
07-06-2005 13:56:45
I've checked my John Deere dealer, NAPA, Lowe's, and a bolt specialty shop and I can't find 7/16" x 3 3/4" bolts for the manifold of my JD60. I can use 3 1/2" bolts but would like that extra quarter inch for more bite. What supplier has this bolts?
Mike M
07-07-2005 05:43:49
 Re: In Need Of Manifold Bolts in reply to StuckRusty, 07-06-2005 13:56:45
I think I always used a little longer bolt without any problems(standard length) just make sure the holes are cleaned out with a tap and I put a flat washer under the heads.Use lots of never-seze !!!!!
Pappy
07-06-2005 19:18:37
I'm getting ready to replace the manifold on my "A" and have found that old Chevrolet 350 head bolts are about the same as I need. I ground the tapered tips to achieve the proper length. The "60" is a little different, but keep in mind that bolts are not specialty items.
Henry J
07-06-2005 17:30:23
Rusty
I try to go the route that Frank suggested of cutting off a slightly (too long) bolt to the right length if there is the proper amount of threads left.
I have read a bunch of threads in the past about not using grade 8 bolts on the manifold, because on most you don't need that kind of strength and they will smoke drill bits if they need drilling out, course that should be the next generation's problem.
F-I-T
07-06-2005 15:30:02
McMaster-Carr has the bolts in 7/16" in 4" and 4 1/2". There a variety of grades and finishes.
You can also cut of and re-thread a 4" a bit higher if you need to, BUT, the parts boook calls out 7/16" by 4 1/4" (6 used). Don't start too short!
Frank
Dup
07-06-2005 15:23:34
Look up Macmaster-Carr on the NET. They should have what you are looking for.
Pat Browning
07-06-2005 14:45:04
StuckRusty -- See below a tip that appears in a book called "A John Deere Model 'H' Restoration Guide." This material (B7 Treaded Rod) should be available from that "bolt specialtly shop" for under $10 for a three-foot section. Get a new blade for you hacksaw and you will be in business. (PatB)
Lower Cost Studs --- Use ASTM-B7 Threaded Rod to make replacement studs for manifold-to-head fastening (not for engine head-to-block). This threaded rod has grade 5 hardness & tensile strength slightly better. Purchase 2H hex nuts to go with the studs; both available at most fastener outlet stores. ++++
