3020 Hyd/Trans noise
Crude K
07-06-2005 13:37:37
I have a 3020 with a front end loader and the syncro transmission. When going forward in first or second gear if I let the clutch out too fast I get a very loud noise in the transmission or hyd and it only goes away when you step in the clutch. It sounds like it is in the hyd pump and will change noise as you raise or lower the loader but not quit. If I let the clutch out slowly I don't have any noise. Any help would be appreciated.
msb
07-06-2005 19:25:31
 Re: 3020 Hyd/Trans noise in reply to Crude K, 07-06-2005 13:37:37
Just a guess without the benefit of hearing the noise.I would check the hydraulic pump coupler.Try tightening (equally)the two bolts that clamp the splined coupler to the pump shaft first.
Crude K
07-07-2005 07:09:43
 Re: 3020 Hyd/Trans noise in reply to msb, 07-06-2005 19:25:31
How and where do I start on the hyd coupler clamps. Thanks for the advice.
msb
07-07-2005 07:53:45
 Re: 3020 Hyd/Trans noise in reply to Crude K, 07-07-2005 07:09:43
Coupler is in front of the engine.Its not easy to get to especially if the tractor has a wide front end on it.
