3010 with seized plug
woodbutcher
07-06-2005 13:15:59
Hey G-man or mathies...a while back you both told me where to find the screen for the hydraulic reservoir. I have located the 2" plug that holds the screen, and it is the 1" square casting, so this is the later model. Do you have any ideas about breaking it loose? Is there a special tool?
I made a socket out of square tube and used my air wrench until I rounded the soft metal in the socket. If I use a crescent wrench on the casting it will probably round the shoulders.
3010 Ken
07-07-2005 04:09:07
 Re: 3010 with seized plug in reply to woodbutcher, 07-06-2005 13:15:59
Hey Mr. Woodbutcher; Checked on that plug last night and my 10"pipe wrench was to big to get in there.But a 1" open end wrench had enough room to fit and like msb said I smacked it with my hand and it came loose.What Pete said about a twelve point socket is true,but I would be careful about using an impact on it and it may have a tendency to round the shoulders of the plug being it's as tight as you say it is. Good luck. Kenny
woodbutcher
07-07-2005 04:59:56
 Re: 3010 with seized plug in reply to 3010 Ken, 07-07-2005 04:09:07
Thanks again to both of you. I'll give it a try today. I have already drained the reservoir, and I'd sure like to check that screen while I'm at it. But one thing leads to another, so I think I'll replace the load control shaft seals, too.
msb
07-06-2005 19:29:24
That plug shouldn't be that tight.A smack with the hand on a large crescent wrench is all it should take.If that doesn't do it then put a large pipe wrench on it and smack the handle with a big hammer.
