Head Studs on a GP
Marty Z
02-26-2004 22:44:48
I broke one head stud off and had a tough time getting the remains out. The new stud grips just fine ,,but I am not pleased with the seal that I get around the stud from the coolant. What is the best sealer for big imperfections ??
Thanks Marty Z
Clooney
02-27-2004 03:11:03
 Re: Head Studs on a GP in reply to Marty Z, 02-26-2004 22:44:48
Marty, about the best I have found for retaining larger loose studs [especially if the fit is a little on the loose side] is Loc-Tite 620 high temperature retaining compound.. You could also use Loc-Tite 680 as that is easier to find but is slightly lower temperature.. The 620 is good for at least 450�F.. If 620 or 680 is used that stud will stay put as long as needed.. The bad news is it won't come out in the future without heating it first,, the good news is it won't rust in place & will come out quite easily later IF heat is used..
[email protected]
Marty Z
02-27-2004 07:15:06
 Re: Re: Head Studs on a GP in reply to Clooney , 02-27-2004 03:11:03
Thanks Clooney, It doesn't wiggle but one side of the hole is boogered up from my chisels and punches..
I'm off to the NAPA store.
Marty Z
