Dash Removal for a 420S
JD Earl
02-26-2004 22:00:49
Well I am trying to get ready for paint and want to take the dash out as well as the steering wheel.
1. What is the best way to remove the steering wheel.
2. I want to take the dash off but I am worried about unhooking the temp gauge out of the head. Do I loosen the small or large nut at the head for the temp gauge.
Thanks for the help. JD Earl
JD Earl
02-27-2004 11:10:18
 Re: Dash Removal for a 420S in reply to JD Earl, 02-26-2004 22:00:49
Thanks for the tips. I will go out and get a puller.
Ray
02-27-2004 05:40:05
I think your doing a lot of extra work for
nothing.I always fix any gauges that don't
work,paint the dash,then when it drys tape it
off and your ready to paint the rest of the
tractor.I remove the steering wheel and leave
it off untill everything is done.I also
remove the throttle lever and paint it seperately.If you remove the battery you can
paint the back side of the dash.
Wayne in Tn.
02-27-2004 04:34:21
Earl, the best way is to use a puller on that steering wheel. I have removed them by using a big punch at an angle and whacking with a big hammer, but if you are saving the wheel, you may put dents in the hub by driving on it. I have a big drift made out of brass that I use.
You loosen the small nut on the sending unit and hold the big one with a wrench. Good luck, Wayne.
