HYGARD hyd./trans.for a 3010...the same as 303?
woodbutcher
07-06-2005 07:36:24
I"m changing the hydraulic/transmission fluid in my 3010. I"ve installed a frontloader, so I"m sure the fluid is contaminated. The shop manual calls for John Deere 303 fluid...is that the same as HYGARD hyd./trans.?
Also, is there a good way to drain the fluid cooling reservoir beside the radiator?
3010 Ken
07-06-2005 09:06:52
 Re: HYGARD hyd./trans.for a 3010...the same as 303 in reply to woodbutcher, 07-06-2005 07:36:24
Hey Mr. Woodbutcher;I called the dealer a few years back with the same question,and like msb said,they told me it replaces the 303 and it's better. Kenny
woodbutcher
07-06-2005 12:55:19
 Re: HYGARD hyd./trans.for a 3010...the same as 303 in reply to 3010 Ken, 07-06-2005 09:06:52
Thank you, 3010 Ken and msb. I have another problem. The cap that holds the screen in place on my 3010 has been there longer than the 10 years I've owned it. I haven't found any way to break it loose. Is there a special tool for this job? Mine is the 1" square casting.
3010 Ken
07-06-2005 13:52:02
 Re: HYGARD hyd./trans.for a 3010...the same as 303 in reply to woodbutcher, 07-06-2005 12:55:19
Hey Mr. Woodbutcher;I believe there may be enough room to get a 10" pipe wrench in there on that square plug.I'll look at mine tonight when I get home and make sure.If your into spending money they may make an 8 point socket to fit that thing but you'd only use it once. Kenny
Pete/ME
07-07-2005 02:43:33
 Re: HYGARD hyd./trans.for a 3010...the same as 303 in reply to 3010 Ken, 07-06-2005 13:52:02
Ken, A twelve pt. socket will work (it's a math thing). I've also used a (!@%^@#) metric one and pounded the sucker on.
woodbutcher
07-06-2005 14:00:03
Thanks, Ken. I'm going to look for a socket so I can preserve the shoulders as much as possible.
msb
07-06-2005 08:29:55
Hy Gard replaces 303 oil.It is improved over the old 303 specs.
