4020 powershift pto spins all the Time
Lucas V
07-06-2005 06:00:59
The PTO on my 1969 4020 powershift sspins all the time. I have checked the linkage took the valve off the side and have found nothing. So I think it is in the brake itself. I was just wonder if if there is any one thing I sould look for. This happened all at once its not something thats been getting worse over time
thank you
ERIC BENTON
07-06-2005 10:58:44
 Re: 4020 powershift pto spins all the Time in reply to Lucas V, 07-06-2005 06:00:59
There is a PTO brake between the clutch hsg and the transmission case. There is a roll pin that holds the brake to keep it from spinning. Over the years the brake has worn the pin into. The brake spinning will eventually cut into the clutch hsg and ruin it. It is generally not an expensive fix parts wise just labor intensive. The tractor has to be split between the engine and clutch hsg to remove the front ps clutch pack and the top 2 bolts? that fasten the clutch hsg to the transmission hsg. Then the clutch hsg has to be bolted back to the engine and then seperate the clutch hsg from the transmission hsg. Brake part number is RE20733 pin part number is R40336 If the brake has cut into the hsg. The hsg can be welded and surfaced to smooth it up. Hope this helps.
