I need help retiming a John Deere 14t Baler.
Darren
07-05-2005 20:24:03
I recently broke the chain that controls the timing of the needles. I have replaced the chain but can't get the needles back in sync with everything else and I keep shearing pins. Is there a way with the chain off to line up the bottom sprocket with everything else to retimethe needles. Also, is there anyone that can help me find an owners manual? The local John Deere dealer says he can no longer get them.
Thanks
Bob
07-05-2005 21:09:18
 Re: I need help retiming a John Deere 14t Baler. in reply to Darren, 07-05-2005 20:24:03
You SHOULD be able to get a manual direct from Deere by calling 1-800-522-7448 (OME16470 @ $30.00).
I have a bunch of extra's, and have had my son sell some on ebay, although he does not have one "up" right now. Email if you'd like a used one.
The basic needle timing is as follows: (BE SAFE, this is done by hand, tractor safely shut off.)
Manually trip the knotter. Turn the flywheel slowly in the direction of normal rotation.
With the plunger moving towards the rear, on it's compression stroke, the needles should rise to the point where they are flush with the top edge of the slot they rise through at the point the face of the plunger is 1" to 2" from the tip of the needles.
If this dimension is not correct, advance or retard the chain drive accordingly, and then manually run it through another cycle, and check it again.
I hope this makes sense to you!
