4230 Underhaul
txgrn
07-05-2005 14:22:49
Ok guys. Fingers are crossed. Started it today and it came on line smooth as silk. Oil pressure gauge also came up much smoother than ever before. 2 qts of syn we are talking about and about 30 minutes of engine operation.
Gonna stay on it. But it I'm right, there ain't gonna be anything in any of my equipment but 100% Mobil 1 if this works out. Just the money I saved on this overhaul would pay my synthetic oil bills for the rest of my life.
Mark
Lee B
07-07-2005 04:17:13
 Re: 4230 Underhaul in reply to txgrn, 07-05-2005 14:22:49
The worshiping of 'wonder lube' noted and resisted here.
I used to subscribe to NASA monthly technical magazine (NASA Notes) where they discussed their many, many patents and other subjects of nerdy interest. Of particular note was the results of their oil testing experiment where they used several including Mobil 1, teflons, graphites, and other popular wonder lubes on their ceramic ball bearings that are used in the space shuttle engines. At $5,000 each they were looking for an oil that would allow two uses of these several dozens of bearings instead of just one. The only oil that gave them NO surface scratches at 20,000 RPM and liquid oxygen temperatures at full pumping load was good ol' straight run 90w. You are just wasting good money in my opinion, changing oil more often would be a much, much better solution, but now you can't afford to!! At least I couldn't afford it, good luck with that.
buickanddeere
07-06-2005 08:35:55
Synthetic is not cure an existing problem. It make coax a little more running time before total failure however. I have traced back the story on several "failures caused by synthetic lubes". Turns out everytime the machine was on it's last legs and somebody was trying to avoid a rebuild by using a "wonder lube". It then seems to get real easy to blame the $9.00 a quart lubricant for not protecting the machine.
3010 Ken
07-06-2005 04:43:13
Morning txgrn.That Mobil one,does it seem thicker coming out of the bottle? I wonder if it might help me to run it in my tractor after I rebuild the engine this winter? Glad it worked for you.I've been using Lucas oil stabilizer for three years and it helped my engine a lot. Kenny
R. John Johnson
07-05-2005 16:47:44
Good to hear Mark! Nothing like having a nagging problem on your machinery fixed.
Still waiting to get mine in the field. Hay is ready, but it is so wet we can't run. Looked at some fields today and MAYBE some high ones could be started early next week.
John
txgrn
07-05-2005 19:36:25
 Re: 4230 Underhaul in reply to R. John Johnson, 07-05-2005 16:47:44
Hi R John,
Thanks!
We finally hit Rain Friday and again last night after a dry June. Thank goodness on this end hay is in the early recovery stage so the moisture is very welcomed and is coming at the right time.
Amazing how many weather vaiables you read about on here from one guy (I think kyhayman) was "celebrating" 51 dry days and then your soggy forecast.
Course the Lousiana and Alabama boys will be celebrating moisture as that little tropical depression should wet things down for them for the next couple of day. Hope they are ready for it.
Hope it dries out for you.
Mark
John Jenkins
07-06-2005 08:01:59
 Re: 4230 Underhaul in reply to txgrn, 07-05-2005 19:36:25
You got that right! Here in Montgomery it�s soggy this morning and it looks like we�ll have it all week long but we need it. It�s pretty dry here.
