2010 narrow front end swap
egerbeaver
07-05-2005 05:50:56
I"ve got a 2010R with a narrow front end that I"d like to replace with the wide one. Are there any modifications needed or can I just bolt on the wide front end pieces provided I can find one in a salvage yard? Any info, tips, or hints will be greatly appreciated. Thanks.
TylerARK
07-05-2005 13:37:14
 Re: 2010 narrow front end swap in reply to egerbeaver, 07-05-2005 05:50:56
If yours is a Row crop (RC) and not a Row crop Utility (RU), I have everything you need to change it over. Is your narrow front held on by 4 bolts ??
Besides the front axle, it also takes two other pieces for the pivot.
We just tore down a 2010 RC with the wide front. If yours is the RC ,everything to change it will cost you $400 plus freight.
If it was a RC utility it would also take the front support and a different steering gear housing which would be a lot higher.
Tyler
L&L Parts & Equipment Co.
www.llparts.com
