??? for F-I-T others
Mike M
07-05-2005 05:33:32
Frank; Do you think that electrolisys would have any chance of working inside of a cyl. bore to help free it up ? I could make an insulated electrode where it goes through the spark plug hole ? Do you think it will eat up the head gasket ?
F-I-T
07-05-2005 06:14:00
 Re: ??? for F-I-T others in reply to Mike M, 07-05-2005 05:33:32
If any of the components were aluminum, I'd be concerned, but I think the edge of the head gasket should be steel, so you should be all right.
So you're trying to unstick an engine without removing the head? I'm not sure that the electron flow will get down into the ring area, since it will be a line of sight reaction. I think the water and the washing soda might do more harm than good since when the solution does penetrate the ring area, you will have the chance for the washing soda to form crystals around the rings amd maybe stick it tighter.
Electrolysis would not be my first choice.
Frank
Mike M
07-05-2005 07:39:11
 Re: ??? for F-I-T others in reply to F-I-T, 07-05-2005 06:14:00
Thanks for the input ! I have not used electrolysis yet. I couldn't even spell it right ! Just a thought I had thinking of a way to remove or loosen up some rust. P.S. Thanks for the spelling lesson.
