3rd gear grinding in 3010
BradB
07-05-2005 04:43:39
Starting to have a problem with 3rd gear. 3010 syncro shift. When I go from reverse to third and let clutch out it grinds because its not all the way in gear. I can adjust the linkage but, only have the problem with third? Would shifting fork cause this and how big of a job to fix??
As always thanks.
billyiron
07-06-2005 07:03:38
 Re: 3rd gear grinding in 3010 in reply to BradB, 07-05-2005 04:43:39
had similar prob with 4020 in 5th,,the shift rods and bellcranks had wore oblong,replaced those items and was okay,,hope yours is an easy fix,,billy
BradB
07-06-2005 13:45:22
 Re: 3rd gear grinding in 3010 in reply to billyiron, 07-06-2005 07:03:38
shift rods and bell cranks? Shift rods I know what are bell cranks?
billyiron
07-06-2005 17:24:35
 Re: 3rd gear grinding in 3010 in reply to BradB , 07-06-2005 13:45:22
right side of trans, looks like a handle,, that the shift rods hook to,,,,billy
Glen in TX
07-05-2005 13:02:48
Have to take the transmission cover off to see what is wore. Probably the dentents have wear or hanging but could also be a syncronizer.
