JD 2010 Cuts out
Matt Pilarski
07-04-2005 23:46:48
Had a quick question on my dad's tractor...
Its a 64-67 John Deere 2010 gas 4cy. Oddly, we were using it to rake the fields the other day, and about 2 hours into using it, it cut out. It seems that every 2 hours of useage, it cuts out. It runs crappy (sputters and eventually chugs its way out) on any throttle setting BUT high throttle. High throttle actually makes it run well...maybe a spring connecting to the carb somewhere? My dad seems to think either air in the lines, or crap in the lines (the sediment bowl had some crap in the bottom when i cleaned it). He installed a secondary fuel filter after the sediment bowl, to double check and make sure any crap hasnt gone past into the engine (the tank might have had some sediment in it)
Right away he wants to get rid of the tractor. I personally love this tractor above any we have (Massey Fuergeson 231 and International 706). It runs so smoothly, doesnt smoke at all.
Any ideas?
Bob
07-05-2005 00:15:54
 Re: JD 2010 Cuts out in reply to Matt Pilarski, 07-04-2005 23:46:48
Check to see if it has spark when it has cut out. Symptoms could point to a bad (heat sensitive) coil, or even a condensor.
Matt Pilarski
06-05-2006 09:54:07
 Re: JD 2010 Cuts out in reply to Bob, 07-05-2005 00:15:54
Problem solved...it was set for negative ground...the system runs on POSITIVE ground!
