29 D rear axle leak
jds
07-04-2005 18:07:22
What kind of seals or gaskets are on the rear axle of a 29 D? I have oil leaks where the axle housings bolt to the main housiing and also at the ends of the axle shafts. Is this stuff available from deere or is it make your own? Also how much slack should there be in the drive chains. Thanks
Glen in TX
07-06-2005 12:27:50
 Re: 29 D rear axle leak in reply to jds, 07-04-2005 18:07:22
Seems like we had trouble getting the outer felt seals and retainers from JD last time. You might try [email protected] for those outer felts. Otherwise if old ones are fair and you measure well a local gasket company can cut some out for you too.
Glen in TX
07-05-2005 13:50:09
On the quill bolts the later styled Ds used 8-10 per bolt of a D933R velumoid washer between the clamp and quill on the inside. Last time we ordered those from JD we got some rubber hose the thickness of that many washers to fit the bolt. You can make those yourself from rubber hose or use other types of sealing washers there. I have also used lead washers there too. The mating surface between quill and housing will have to be cleaned after the housings are off and just use a film of grease between them on assembly or you will have a problem with future chain adjustments. They need to come off anyway to do the job right and get the axle felts aligned right. To adjust chains have your tractor jacked up so the wheels can be turned forward a few turns and where the chain is tightest you should have 1" of slack. Rotate the top of axle quills forward in direction of arrow on case to adjust. Rotate wheels several turns forward again to make sure chain isn't too tight. A copy of Dir. 108 from JD or other vendors will help you a lot on the axle rebuild and other maintainance for your D.
Nick from Indy
07-05-2005 12:26:51
I use a flat rubber type oring. kind a like the oring in your garden hose. on the bolts in the main housing. deere never used any gaskets. If you look at archive pics the tractor will have oil leaks. Hope this helps nick
