HELP with front steering pedestal problem on mt
steve k corum
07-04-2005 17:45:37
working the old thing and all of a sudden the lower spindle fell down. if you jack up the tractor the front wheels stay on the ground. what hold the up splined shaft to the lower spline shaft i can`t find my manual, any help be helpful thank you stevec
Chooch
07-05-2005 12:42:05
 Re: HELP with front steering pedestal problem on m in reply to steve k corum, 07-04-2005 17:45:37
Steve,
I am going from memory here, but I believe there is a splined coupler that connects the upper spindle to the lower spindle. To get to it, you have to remove the steering box and upper spindle support. The lower spindle is inserted from the bottom of the tractor. The coupler is installed on the part of the lower spindle protruding above the front end casting and a roll pin inserted thru the coupler and lower spindle. The upper support is re-installed along with the steering box. The upper spindle is then slid down from the top, thru the upper support and into the splined coupler. The steering box cover is then re-installed and adjusted.
If you have access to a fax machine, send me your number and I will fax you a copy of the manual.
Chooch.
