720D Flywheel
AR Roger
02-26-2004 18:59:36
Hey guys. My brother needs some help with a loose flywheel on a 720d with a pony. What is a "Taperlock" , how does it work & any idea where they are available in Ontario? He said his flywheel has cracked & now the wheel has turned & the splines are stuck together. I haven't seen it, but does this sound like a Taperlock fix, or a crank & wheel to fix him up? Thanks from us both!!
buckeye al
03-01-2004 15:08:22
 Re: 720D Flywheel in reply to AR Roger, 02-26-2004 18:59:36
My 70 D has had a taper lock on it since the mid 80's. My original flywheel cracked through the bolt bosses & started to pound real suddenly. Neither the flywheel nor the crank had any visable damage. I was lucky. The noise came on suddenly and the cracks were plainly visible. Pounding went away just as suddenly when the taper lock was installed.
Be sure to adjust your free travel carefully.
AR Roger
03-02-2004 17:49:51
 Re: Re: 720D Flywheel in reply to buckeye al, 03-01-2004 15:08:22
Thanks,buckeye. I'll let him know about the sucess of the Taperlock & advise him about the crank end play! Thanks again. Roger.
Hal
02-27-2004 15:14:42
I have a taper lock on my 70D and 730D they hold on the crank real good if you put them right. the splines on my 70 were pretty bad and I put the taper lock on about 6 years ago I got it from Dennis Polk in Indiana.
Bo in Maryland
02-27-2004 04:40:43
..... I don't know about taperlock flywheel suppliers in Ontario but you might try Dengler Tractor in Ohio..... last time I checked they had taperlocks and a lot of other 2-cyl parts too..... .
Link
Good luck to all!
Bo
AR Roger
02-27-2004 04:46:40
 Re: Re: 720D Flywheel in reply to Bo in Maryland, 02-27-2004 04:40:43
Thanks for the help. We'll give them a call!!
