Adjusting JD A Clutch
yoyo
07-04-2005 14:24:17
The clutch stays engaged all the time regardless of the position of the clutch lever. It snaps in normally and snaps out normally but it does not release. What can I do to correct this problem.
Pappy
07-04-2005 22:28:13
 Re: Adjusting JD A Clutch in reply to yoyo, 07-04-2005 14:24:17
I would suspect that the clutch linings are stuck to the driver or pulley. Pull the driver and take a look. Some of the "A"'s have two clutch discs and some three. A good cleaning should solve the problem.
steve k corum
07-04-2005 17:50:13
sound like you need to pull the clutch pulley and free up the clutch disk. or it is over tighten. has it been sitting or did it happen all at once stevec
xragman
07-04-2005 17:48:28
If ( it snaps out normally ) it will release. I say dissassembly of unit to find problem. Could be many different things wrong.
shotgun
07-04-2005 15:16:23
is it overrideing when you pull it back?
