phrankndonna
07-04-2005 10:24:29
Hello, I've got a JD 212, and originally, I had a problem with the electric lift for the mower deck. I replaced one of the celenoids, and that fixed that problem. However, no sooner was that problem fixed, and another problem reared its ugly head. With the tractor running, when I would hit the PTO switch to engage the mower deck, the engine would die. I disconnected the clutch to determine if it was possibly the clutch starting to freeze up and putting too much of a load on the engine, but the engine still died. And it was immediatelly as I started to engage the switch. I replaced the switch, but it still would die. Now, the engine won't even turn over. The battery is good, and the electric lift still works, and you can hear the clutch engage when the PTO switch is flipped on, but the starter to the engine doesn't even engage. Using an ohm meter, I checked to see if there was power going from the battery to the starter, and there isn't. I checked with just the key on, and I checked with turning the key, and either way, no juice goes to the battery. I checked with the positive end on the starter, and no juice. I also checked with the positive end on the 'relay(?). First I checked the post where the positive cable from the battery goes in, and of course there was power. I then checked the other post where the line goes out to the starter, and there was no juice. My initial response was the relay must be bad. But, my initial response before was that the PTO switch must be bad, and I was wrong. I'm wondering if it is indeed this relay, or could it be the starter switch? Or could it be something entirely different that I haven't considered? I appreciate any input. Frank
