50 muffler
Trump
07-03-2005 17:40:23
I want to etch the galvanizing on a new muffler before painting. Is vinegar strong enough for this, or do I need to use something like muriatic acid?
F-I-T
07-03-2005 18:41:57
 Re: 50 muffler in reply to Trump, 07-03-2005 17:40:23
Trump:
The old timers said vinegar was strong enough to etch galvanized gutters prior to paint, but I stll had a lot of it peel later. I think I would use some Muriatic acid with a mask and squirt bottle, or brush it on so you can keep it on the outside only. Might nuetralize with a bit of baking soda water and then rinse it throughly.
Frank
RalphinWI
07-04-2005 07:24:32
 Re: 50 muffler in reply to F-I-T, 07-03-2005 18:41:57
I would dilute the muriatic acid with a good bit of water unless you want to strip all of the zinc off. Straight muriatic acid is pretty aggressive on steel itself. On he other hand, if you are painting with High Temp Paint you may want to temove all of the zinc.
Trump
07-03-2005 19:18:12
Thanks Frank, I'll give it a try tomorrow.
Trump
07-03-2005 20:23:45
 Re: 50 muffler in reply to Trump, 07-03-2005 19:18:12
It is a cheap aftermarket muffler and it was all painted up. By the time I took it out of the box,paint started falling off. I wire brushed it clean to bare metal in about 3 or 4 minutes. I think the old 2 cylinders came with unpainted galvanized mufflers, but the painted black with high temp. satin looks much better. I don't know, I just do these things.
Trump
07-03-2005 20:23:00
