H BRAKES
HERMAN
07-03-2005 14:23:13
HOW DO YOU FIX THE BRAKES ON A H JD .They are not external like a 50 or an A.Can they be adjusted .No brakes now at all.
Pat Browning
07-04-2005 07:07:58
 Re: H BRAKES in reply to HERMAN, 07-03-2005 14:23:13
HERMAN -- When you have a JD "H" tractor whose brakes do not grip at all, and for which the adjustment is already at its limit or is frozen up, you will absolutely need to remove the axle assembly for each one to do repairs as necessary. And believe me, the grief inside that cavity can run the gambit.
At first read of your description of the problem, I jumped to a couple conclusions; especially since you compare what you now have to a JD 50 or an "A" tractor.
On the model "H," the main thing owners most always overlooked was to keep open the weep holes that are at the very bottom of each rear axle casting, immediately back from its interface with the main case. These are 1/4" diameter holes which, if kept open, allow condensation and also oil from the differential to escape -- thus protecting the brake lining (and shoe) from wrecked by either water or oil, or a combination of the two -- a colloid. The latter is usually found when one opens those rear axle cavities on the "H" tractor.
The plan you make should include renewal of the rear axle seals contained in the main case. And the best access to them is to have both rear axle assemblies removed at the same time. And as usual, there is the dangers involved when removing both rear axle assemblies as Mike mentioned. You also will be removing the rear cover to the differential cavity. I leave it up to you to decide how to stabilize the tractor when blocked up to remove the axle assemblies. But be sure you use your noodle to protect yourself and anyone who may be in the area from time to time.
If you have the JD-4 Shop Service Manual from I&T, you are fairly well armed with the right data. And if you do not have one, Charles Lindstrom, 913-365-5500 has about as good a deal as anybody, on the books you should have (Operators Manual, Parts Catalog, & Service Manual) as you will find around. He is very fair and easy to deal with so far as parts is concerned too.
Now for brakes -- when you have the drums and shoes extracted, I recommend a service shop like one with the words "Brake & Clutch" in their business name to do the work for you. Those drums can be turned easily if they need it, and the Brake & Clutch shop can mount your new John Deere brake linings for you without breaking them. I DO NOT recommend automotive type brake linings for use in the JD "H" tractor -- they shudder & grab too much, and make excessive noise.
Before tearing into your tractor's rear end, I strongly urge you to purchase the I&T Shop Service Manual cited above. If, on the other hand, you intend to rely on this forum for your guidance, I reckon you will ask when you get into trouble. There are some nuances you will run into with or without the service manual, and two of them are (1) Adjustment of the rear bearing loading, and (2) removal of the brake drum reference snap ring should you elect total disassembly of the rear axle assembly -- disassembly beyond that needed to gain access to the brakes. When you get to this stage, call on me -- I can help. [email protected] or 830-627-0430.
F-I-T
07-04-2005 07:36:04
 Re: H BRAKES in reply to Pat Browning, 07-04-2005 07:07:58
Pat:
It's not a colloid. It's an emulsion.
Frank
F-I-T
07-03-2005 19:15:58
third party image
Herman:
While the brakes on the "H" are internal, the mechanism is pretty much the same as the 50 and the "A", with expanding shoe design. The adjuster that you are familiar with is on the front side of the housing and by turning it inward (see red arrow), the cone end with four notches will move inward and will spread the pivot point end of the shoes so that the pedal movement alone can make the shoes contact the drum. Just like the 50 and the "A", the adjuster can become frozen, and to free that up generally requires removing the housing. Since the differential is supported by the two axle stub ends, if you remove both housings at once the differential will fall out of place and require that you remove the rear cover to re-install. Next you would have to use a suitable puller on the drum and then remove the shoes. A second problem is that sometimes the pedal can even freeze up. I have an "H" waiting for this same problem of one stuck pedal and two stuck adjusters, so I'll be spending some quality time with the torch warming things up and working out the rust.
If your adjusters are loose, you still have brake material left, and the internal mechanism is operating correctly, you can try turning each adjuster in while moving the pedal with the other hand until you have removed most of the slack. You'll want some free pedal travel, but how much is generally up to the user. An inch is a good number, though some like less.
Frank
dan_41jdh
07-04-2005 15:00:49
 Re: H BRAKES in reply to F-I-T, 07-03-2005 19:15:58
Frank,
Contrary to logic, one should actually strive for quite a bit of free pedal travel. I learned this from an old service bulletin. The reason for this is because of the profile of the brake cam mounted to the brake pedal shaft. This cam acts against the shoe rollers, and forces the brake shoes outward. If the brake shoes engage the drum before the cam is rotated to its most mechanically advantageous profile, the brakes seem to be weak, and excessive pedal force is required. The service bulletin also states that excessive brake wear is likely because of insufficient shoe-drum clearance if intended clearance isn"t maintained. Proper adjustments are as follows:
Models A, G, GM, H: "To tighten brakes, use 6" wrench and tighten adjusting screw down snug. Back off five notches. This should permit 2-3/4" to 3-1/4" pedal travel before brake contacts drum."
Model B: "To tighten brakes, use 6" wrench and tighten adjusting screw down snug. Back off four notches. This should permit 1-1/2" to 2" pedal travel before brake contacts drum."
F-I-T
07-04-2005 16:23:06
 Re: H BRAKES in reply to dan_41jdh, 07-04-2005 15:00:49
Dan:
You are correct. I double checked the 70D manual and it does indeed say to turn adjuster to tight then back off five notches.
Thanks!
Frank
Pat Browning
07-03-2005 15:58:34
Herman -- To get at the brakes, you have to remove the rear axle assembly from the tractor. You are encouraged to write me for a detailed work plan. email is [email protected]
As soon as I hear from you, I will begin to share with you the details you need to know. Whatever you do, don't remove both rear axle assemblies at the same time unless you want to open up the differential part of the main case. PatB
Mike M
07-03-2005 20:22:10
 Re: H BRAKES in reply to Pat Browning, 07-03-2005 15:58:34
I am pretty sure I have done both at the same time ,it's been awhile. I think the biggest problem is keeping the tractor from falling over ! I would use a light chain and binder and fasten a 4x4 to the front frame and then stick a jack stand out on each side to hold the front end. On that differential I don't think they have much extra clearance in there so they don't move too far away. I probabally work it in place from the oposite side while putting in one side ? It's been awhile ,but I'm sure I did it. Always put in new oil seals as that is the main cause of no brakes on an H.
HERMAN
07-04-2005 19:47:52
 Re: H BRAKES in reply to Mike M, 07-03-2005 20:22:10
Appreciate the help very much.Gives me an awful good idea of how to fix thanks again . herman
