1268R Front Wheels for '49 A
Dave in SV
07-03-2005 09:21:59
I have one warped front wheel on my '49A. At a swap meet in Moline yesterday, a vendor had some 1268R's for sale... pretty tough looking, though (considerable rust and in need of repaint). I told him I can buy NEW from JD, already painted yellow... he said that if that's true, new wheels are not as good as the old ones.
Regardless, he mentioned rivited wheels-vs-welded wheels. Any opinions as to which is better and/or more authentic for my vintage? Any idea if the new wheels from JD are rivited or welded?
Duane Larson
07-03-2005 10:20:44
 Re: 1268R Front Wheels for '49 A in reply to Dave in SV, 07-03-2005 09:21:59
Dave,
I believe Deere front wheels went from rivets to spot welding sometime in 1951, based on observations over the years. Deere never made the pressed steel front wheels - they were bought from one of many suppliers. The manufacturer, date, and Tire and Rim Association stamp are often found stamped inside the rim (ie, on the metal under under the tube). Most of the old manufacturer's have been bought out, and Titan Wheel is now one of the primary providers. According to JDPARTS.COM, the JD1268 has been replaced by the JD1291 wheel, which, according to the pix, has four slots, four weight holes, and only six holes at the bolt plate (the 1268 has 6 bolt holes plus 3 weight holes in the bolt circle). So it does not look like the 1268.
A vendor at our show last weekend had several JD1268R wheels, including one NOS and one that looked barely used. Keep looking - a good 1268 should not be that hard to find.
Dave in SV
07-03-2005 11:46:50
 Re: 1268R Front Wheels for '49 A in reply to Duane Larson, 07-03-2005 10:20:44
Thanks for the info!
