3010 Engine Problems. OUCH!!!
Dave Brennan
07-03-2005 08:09:17
I pulled a 3010 Diesel apart a few days ago and found crank balancer teeth in the oil pan. Both of the gears have teeth missing. Ouch!!! Is this a common problem for this model??? The engine has spun number three rod and number four and five mains are chewed up real bad but not spun.
msb
07-03-2005 11:42:33
 Re: 3010 Engine Problems. OUCH!!! in reply to Dave Brennan, 07-03-2005 08:09:17
I don't ever remember seeing a balancer block with missing teeth.Have you checked the balancer drive gear on the crankshaft?If it is bad then you are talking a new crankshaft.
Dave Brennan
07-04-2005 06:15:46
 Re: 3010 Engine Problems. OUCH!!! in reply to msb, 07-03-2005 11:42:33
Funny thing. There aren't any teeth missing off of the gear on the crank, just off of the balancer gears, about one third off of both of them. The crank is sick as it is, so it will need to be turned or replaced. So, I take it this is not a common problem.
crankermike
07-04-2005 08:29:44
 Re: 3010 Engine Problems. OUCH!!! in reply to Dave Brennan, 07-04-2005 06:15:46
You can buy new crankshaft for 950.00, call me 816-586-2841
