4020 fuel leaks----solved
Tom/Idaho
07-02-2005 18:05:43
#1 Awhile back I posted about leaking injector return lines on Bendix injectors. I tried ALL the suggestions including replacing the hold down bolts with new ones. Numbers 1, 3 & 6 would not seal. I used steel washers and copper washers after washing with laquer thinner. Finally got 1 & 3 to stop using copper washers, but #6 still seeped fuel. Talked to the pump/injector rebuild guy and he said that years ago IHC made a Teflon centered washer that would "stop a fire hydrant". Found some at IHC, part # 670207C11 ( IHC just loves it when you tell them you need an IHC part to fix a JD). NO MORE LEAKS..... ..... .....Period..... no more leaks.
#2 On my 4020 the amp light socket shows 12 volts with my meter but will hardly light a test light or 12 volt bulb. I have two new batteries and the light goes out as RPM's come up. I have a wireing diagram. Any ideas?
#3 On the steering column: how does one separate the two aluminum (hub from shaft)? Appears the two have oxidized together and I need to take them apart to put a new shut off rod and parts in.
Thanks for all assistance. Tom/Idaho
jd jim A
07-03-2005 18:46:37
 Re: 4020 fuel leaks----solved in reply to Tom/Idaho, 07-02-2005 18:05:43
yep, had the same problem with the high pressure lines on a 4010. Told new parts guy at Deere dealer I needed the copper washers, he said he'd have to order them. I couldn't belive they didn't have such a seemingly common part. When I installed the new copper washers, most of the connections leaked. Went back to the dealer, talked to someone who has been around these things, found out they keep the Case-IH teflon washers on the shelf! Work great!
txgrn
07-03-2005 05:52:04
Other than a problem as HTR mentioned, it is possible that you are experiencing a normal indication with the charge light.
I have a 4010 and it has the 24 volt system but the system is grounded in the center and no single wires, resistors (that I know of), or fuses like mother deere added later.
If I start the engine at idle throttle setting (cold) the light will stay on (cause the gen isn't putting out anything to speak of and acts like ground to the light).
If I immediately rev the engine (1500 or so) and back to idle it goes out and then comes back on but very dim. If I run the tractor enough to put the starting power back into the batteries, I can idle with the light out. I don't have a problem with this as I have 2 650 cca batteries and the gen only puts out 22 amps as I recall.
On the 12v bulb and applied voltage, I haven't traced it out but it is apparently only monitoring one side of the 12v system. It is wired to either the A or B batteries and if the gen output is low, current flows from the batt thru the light to the gen (I guess; where else would it go).
When the gen starts putting out voltage (at increased rpm's) with the voltage from the gen on one side of the bulb and the batt on the other, the voltage difference across the bulb is progressively reduced till there is not enough difference to light it (to be seen).
Then when the gen is spinning fast enough, the current actually reverses (cause the gen is putting out 28ish volts now and the batteries are at 26ish)...bulb only sees half of this, but not much as you only have about a volt or so differential across it during full charge and it is out.
HTH
Mark
HTR
07-02-2005 19:10:57
The 4320 used the Teflon washers on the injection pump, where the fuel lines adapt to the JDB pump.
If your 4020 has the cross over cable, from battery to battery, there is a resistor in the gen. light circuit. This prevents 24 volts from melting the gen. light lens, if you blow the fuse in the small ground wire on the left battery. That is why you have low current in the gen. socket. It is a path of least resistance thing.
Tom/Idaho
07-03-2005 07:00:36
 Re: 4020 fuel leaks----solved in reply to HTR, 07-02-2005 19:10:57
The serial number is 68020 and the right battery is hooked POS to starter and Neg is grounded on the case. Left battery is Neg to starter solenoid and Pos is grounded to the case. I can't find a fuse or fuseable link in the wiring diaghram or on the tractor. When I turn the key on the amp light is very dim (probably couldn't see it with the cover on)and the oil light is bright. Both go out once the motor starts. I would think both lights should glow the same so they can be seen when they are assembled and in the dash.
Thanks for any help, Tom/Idaho
